Test No. VS19  Find the stress concentration in a
        filleted notch when torque is applied.
        Definition
                Figure 1 .
            The shaft is fixed at one end and a torque of 0.19625 lbf-in is applied on the other
                end. Shear stress is calculated as 1 psi using the following equation. The units are
                    IPS.
Where,
                                            c
                                            MathType@MTEF@5@5@+=
                                                feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn
                                                hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr
                                                4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9
                                                vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x
                                                fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4yaaaa@36DB@
                                                d
                                                2
                                                fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamizaiaac+
                                                cacaaIYaaaaa@384B@
                                            J
                                                fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOsaaaa@36C2@
                                                  π
                                                  d
                                                  4
                                                  32
                                                fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaaSGbaeaacq
                                                aHapaCcaWGKbWaaWbaaSqabeaacaaI0aaaaaGcbaGaaG4maiaaikda
                                                aaaaaa@3B1D@
                        Model Dimensions
                        D = 2 in
                        d = 1 in
                        r = 0.05 in
                        r/d = 0.05
                        D/d = 2
        Results
                        τ   =   K
                            τ
                            0
                        fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqiXdqNaaG
                        PaVlabg2da9iaaykW7caWGlbGaeqiXdq3aaSbaaSqaaiaaicdaaeqa
                        aaaa@3F4F@
                        K   ∼   1.7
                        fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4saiaayk
                        W7cqWI8iIocaaMc8UaaGymaiaac6cacaaI3aaaaa@3D30@
                 The following table summarizes the stress results.
                                Theory1
                                SimSolid
                                % Difference
                                Shear stress
                                1.72
                                1.6885
                                ~1.8
1   Page 1030 ,
                Shigley’s Mechanical Engineering Design, Ninth Edition, Richard G Budynass and
                J.Keith Nisbett
